Minerva Bug?
Minerva Bug?
* The value in d1.l is used to decide what sort of restart is required:
*       bit(s)  value   meaning
*       0       0       do the full memory test
*               1       skip the memory test for a quick reset
*       1       0       scan rom slots
*               1       skip the rom slots, unexpand the m/c
*       2       0       normal establishment of memory size
*               1       take the upper memory limit below as gospel!
*       3       0       monitor mode
*               1       tv mode
*       4       0       wait for f1-f4 selection
*               1       skip the f1-f4 selection
*       5-6     0..3    extend supervisor stack by 0K, 8K, 16K or 24K
*       7       0       set single screen
*               1       set dual screens
*       8-13    0..63   extra blocks of 64k between last screen and system vars
*       14-31           upper limit on memory (0 = no limit)
* (Note that the top bits of d1 are unlikely to ever make sense as memory!)
Does not seem to agree with the code
        btst    #2,d5           is this a forced limit?
        bne.s   res_a5          yes, go use it, whatever it is!
I think that should be a beq.s?
Re: Minerva Bug?
No, why? Comment and code agree here.
Re: Minerva Bug?
mk79 wrote:No, why? Comment and code agree here.
If I set bit 2 Minerva is ignoring the ram limit set, and going ahead and detecting ram. Which means its then putting ramtop the wrong side of the extended screen in uQlx/sQLux!
If I leave bit 2 clear it works as though RAM limit is used!
Re: Minerva Bug?
XorA wrote:If I set bit 2 Minerva is ignoring the ram limit set, and going ahead and detecting ram. Which means its then putting ramtop the wrong side of the extended screen in uQlx/sQLux!
I haven't tried it, but from the code if you set bit 2 the jump to res_a5 will be taken an a5 used as limit (which is derived from d1). If bit 2 is clear it will start the RAM boundary scan.
Re: Minerva Bug?
Im going to have to kick the uQLx codebase a bit more and see if I can get it to give me reliable output of the opcodes it runs then!
Re: Minerva Bug?
Just tried it on an SGC QL, "CALL 390,$00200004" works as expected, giving me 2MB.
Re: Minerva Bug?
mk79 wrote:Just tried it on an SGC QL, "CALL 390,$00200004" works as expected, giving me 2MB.
Thanks, must be an unintended side effect somewhere in uQLx code (this has never worked in original code due to missing brackets)
Re: Minerva Bug?
go_key
        moveq   #io.fbyte,d0
        trap    #3
        addq.l  #-err.nc,d0     check if timed out
        beq.s   set_mde1        yes, just use what we started with
        addq.b  #8,d1           f5 key = $f8
        add.b   d1,d3           check if {ctrl+}{shift+}f1-f4 (d3.lsb = $10)
        bcc.s   read_key        not f1-f4, read again
        roxl.b  #5,d3           set quick reset bit and dual to extend
        ror.b   #3,d3           slide TV/128k/ROM/quick bits down
        roxr.b  #1,d3           slip in the dual bit
        moveq   #$40000>>16,d1  start getting 128k mask ready
        bset    d1,d3           flag byte now: dual/0/0/f1-f4/TV/128k/ROM/quick
        and.b   d3,d1           isolate 128k bit
        swap    d1              put it up in msw, now $40000 if 128k requested
        move.b  d3,d1           d1.l now ready for re-reset call
        move.l  (sp),d3         get top of stack
        move.l  d1,(sp)         replace top of stack
        eor.b   d1,d3           check which bits differ
        and.b   #%10000110,d3   do dualscreen, 128k and romscan bits agree?
set_mde1
        beq.s   set_mode        yes - we're happy to leave that as it is
        jmp     390             no - go to magic reset location with d1.l set
Ok, found out why I was seeing the wrong branch, I was only seeing the 2nd pass though, caused by hitting this condition above. Now just to work out why!
