ZEsarUX 10.0
chernandezba
ZEsarUX 10.0
Post by chernandezba »
ZEsarUX 10.0 is out! Download it from :
https://github.com/chernandezba/zesarux ... s/tag/10.0
Changes:
Version 10.0 - Clive Sinclair edition. 4 October 2021
There are lots of changes in this version, but some of them are remarkable:
- New machine emulated: Sega Master System
- "Time machine" features: Automatic Snapshots to RAM + Rewind feature, backwards debugging, backwards run
- Realtime translation of text adventure games in a ZEsarUX window
- Can render any image from a Speccy Text Adventure (supported parsers: Quill, Paws, Daad, Gac)
- Added Visual Real Tape. Now you can have an audio render of your tape, see tape blocks and rewind or move forward the cassette player
- Can now browse Basic variables on ZX Spectrum, ZX81 and ZX80
- Allow customize upper buttons to actions
- Added Window View Sensors to graph internal emulation sensors, performance, statistics, etc
- Added menu language selection between default (English) and Spanish. Only some texts are translated to Spanish
The full changelog for this version 10.0 is:
Added Sega Master System emulation
Added .sms file viewer
Added midi output and .mid support for QL and SN audio chips (Master System, SG1000, etc)
Added Automatic Snapshots to RAM + Rewind feature
Added new improved real tape loading algorithm
Added setting to disable TZX pauses
Added zsf to scr support for Next, ZX-Uno and TSConf snapshots
Added Jupiter Ace 51 KB RAM emulation
Added Fuzix ide image on the zesarux-extras package
Added TK90X v3 roms by Rodolfo Guerra on the zesarux-extras package
Added ZSF snapshot support for Jupiter Ace, Z88
Added --slotcard-num setting to insert a Z88 card in a numbered slot (1, 2 or 3)
Added ZEsarUX logo on the window footer
Added setting to disable ZX80/81 tape traps
Added wav/rwa/smp tape audio browser, to view Spectrum/ZX80/ZX81 tape blocks from audio file
Added ZRCP commands:
-mmc-reload: reload MMC image
-snapshot-inram-get-index: Returns index to a RAM snapshot position
-snapshot-inram-load: Loads the RAM snapshot from position
Added file converters:
-wav/rwa/smp to tap
-wav/rwa/smp to p
-wav/rwa/smp to o
-rwa to wav
Improved Debug CPU Window:
-Added backwards debugging, backwards run
-Added cpu history menu to see registers in the past (same as you already had on ZRCP)
-Mouse accions: click (toggle breakpoint, change registers), scrolling up/down by using the mouse wheel
-Improve window refresh when pressing keys on non-step mode
-Preserve step mode when assembling
-Added new key to set PC=PTR
-Added new key to go to next breakpoint type PC=dir
-Allow to define up to 100 breakpoints (same that you could define using ZRCP)
Improved Debugging:
-Can now browse Basic variables on ZX Spectrum, ZX81 and ZX80
-Added setting to show location address of every basic line and current line on menu View Basic
-Added Window View Sensors to graph internal emulation sensors, performance, statistics, etc
-Added command line setting to load source code
Improved ZX Vision menu interface:
-Added GUI styles: BeOS, Bloody, Grass, Ocean, Sunny, Panther, Sky
-Added actions for reinsert, rewind, ffwd real tape
-Added setting to pause cpu emulation on menu when multitask active
-Added Degraded ZX Desktop Fill Type
-Added button on footer to switch ZX Desktop
-Added Accessibility->GUI settings as a quick way to enable some GUI enhancements: high contrast style, hotkeys, etc
-Added item to reduce+rearrange windows
-Added some graphical meters on AY Registers, Core Statistics
-Added setting to disable boxes around lower and upper ZX Desktop Buttons
-Added support for accentuated characters
-Allow customize charset
-Allow customize upper buttons to actions
-Real tape icon now is animated when playing tape
-Reorganized GUI Settings and Window Settings menu: "GUI Settings" menu is now called "ZX Vision Settings", "Window Settings" menu is now called "General settings"
-Machine manufacturer list is now sorted by name (instead of some kind of mixed age and type)
-Show in file selector when a file can be expanded
-Improved screen file previews: any file size of 6912 bytes is guessed as Spectrum screen
-Maximizing windows now take care of size of ZX Desktop, when setting "Open menu on ZX Desktop" is enabled
-Handle when clicking a window when menu closed
-Colour palette window now shows all colours that fit in the window
-View sprite legend now adapts to size
Improved Next emulation:
-Turbo setting: make it by default limited on NextZXOS
-ZSF snapshots include all info from port 123b (previous TBBlue .zsf snapshots are incompatible with this version, sorry!)
-Added a splash message when changing Layer 2 modes
Improved Text Aventure Features:
-Improved detection of Daad aventures on debugging
-Now you can render any image from a Speccy Text Adventure (supported parsers: Quill, Paws, Daad, Gac)
-Now you can use a text speech script which can translate text from the game and show the translated text on ZEsarUX window
Improved Find menu: now can find several bytes and open Hexadecimal Editor on the results list
Improved Audio to .mid exporter: allow changing instrument
Improved configuration file: increased maximum allowed size to 256kb and 2000 parameters
Improved curses driver on ZX80/81: now realvideo mode can use extended utf-8 blocky characters
Fixed file previews on corrupted files: pzx, tap
Fixed rearranging windows and using total window height
Fixed Next ULA Scroll to use registers 0x26 and 0x27
Fixed Next tbblue port 123b behaviour: 48kb ram paging, shadow display, 3bit offset, read access
Fixed cpu-step behaviour the first time it's executed
Fixed cursor keys up/down on Jupiter Ace
Fixed --help and --experthelp settings: do not parse configuration file when showing help
Fixed autoload on spectrum 48k+ spanish
Fixed loading ZX80/81 Snapshots/Tapes when filename has more than one extension
Fixed wave shape type "Scroll" on View WaveForm
Some other minor bugfixes and improvements
Enjoy!
ZEsarUX
vol
Re: ZEsarUX 10.0
Post by vol »
chernandezba wrote:ZEsarUX 10.0 is out! Download it from :
Thank you. I tried to use it under Linux and got rather a complete failure. The keyboard is almost nonfunctional. :( My program that uses a software timer via MT.LPOLL doesn't work, the timer always returns 0. :(
EDIT.
I have just tried to run QSBB, it failed too.
Popopo
Re: ZEsarUX 10.0
Post by Popopo »
Last version is nowadays ver12.
But I couldn't find too much information about what it gives to emulate a stock Sinclair QL with MDVs and so on.
I am evaluating different solutions to decide which one could be the best (for my goals) to program from Linux in C for QL.
Also I see you didn't get an answer about your issue. :(
swensont
Re: ZEsarUX 10.0
Post by swensont »
Popopo,
I'm 100% Linux on my home systems. The two QL emulators I use are SMSQmulator (for emulating SMSQ/E) and sQLux (for emulating QDOS). C68 works fine on both platforms. If using sQux, make sure to load the Pointer Environment. It makes switching between the editor, the compiler output and the command line easy.
Tim
Re: ZEsarUX 10.0
In case you want more choices, QPC2 works perfectly fine with Wine
Re: ZEsarUX 10.0
tofro wrote: Tue Feb 18, 2025 8:59 am In case you want more choices, QPC2 works perfectly fine with Wine
Excepty for physical access to floppies! I can confirm the above as I've been using WPC2 since it came out, on Linux, under wine.
Popopo
Re: ZEsarUX 10.0
Post by Popopo »
swensont wrote: Tue Feb 18, 2025 12:49 am Popopo,
Tim
Thank you for the suggestions.
By now I was using QEmulator with a virtual machine running Win7. But too big, isn't it?
SMSQmulator and sQLux, I will try SQLux firstly. I wanted but if I am not wrong, that could emulate something that I need. Not easy installation if I am not wrong but with time... I could deal with it.
I have not the PE. sorry if I sound naive... what gives me that in order to emulate a stock QL ?
SMSQ/E no idea what it gives. Since I have only a QL with Minerva+TK II, my idea is to program or emulate that system the closest possible.
SMSQ/E es an OS for the board for PC, isn't it?... or there is stock QL with those ROMs working around?
I have tried Zesarux and it is not for me. It was unusable in my Linux
Popopo
Re: ZEsarUX 10.0
Post by Popopo »
Is there any comparative about pros and cons?
I could try it out in a VM too, but I wonder what each emulator gives and cannot offer (talking about emulating hardware).
Thank you too tofro
Popopo
Re: ZEsarUX 10.0
Post by Popopo »
NormanDunbar wrote: Tue Feb 18, 2025 3:26 pm Excepty for physical access to floppies! I can confirm the above as I've been using WPC2 since it came out, on Linux, under wine.
WPC2? that is new for me, is that the name to search it?
Thanks
Re: ZEsarUX 10.0
Popopo wrote: Sun May 04, 2025 10:00 pm
Thanks
I think its, QPC2
