esp8266 esp-01
- Sparrowhawk
esp8266 esp-01
I'm looking for an ESP8266 ESP-01 serial WiFi module with the AT commands already in the firmware. I looked on Amz but the reviews for all of them were so mixed that I have no idea whether they were of good or poor quality there.
I tried pimorini and element14 but neither seems to stock them, surprisingly.
Can anyone recommend a brand and the best place to order one online in the UK?
Thanks
JY
Thanks
JY
a.k.a. Jean-Yves
Re: esp8266 esp-01
I just did a Google search and saw that there is a SEEED version, at:
Farnell:
https://uk.farnell.com/seeed-studio/83- ... price=true
Farnell:
- Sparrowhawk
- Sparrowhawk
Re: esp8266 esp-01
Ouch. Just tried to order one and it seems that it comes form the US, so one unit costs £38.95 with shipping!!!
a.k.a. Jean-Yves
Re: esp8266 esp-01
https://www.seeedstudio.com/WiFi-Serial ... P8266.html
Looks like you may be able to get a version direct from Seeedstudio...
Although this looks like a better match picture wise:
https://www.seeedstudio.com/WiFi-Serial ... -2485.html
- Sparrowhawk
Re: esp8266 esp-01
I will blame you for drawing my attention to that device
I think it may be on my 'get one' list now
Re: esp8266 esp-01
Ebay has tons of them for a few pounds PrOf just search "wifi serial transceiver module"Pr0f wrote:I will blame you for drawing my attention to that deviceI think it may be on my 'get one' list now
Like this
https://www.ebay.co.uk/itm/263647348836 ... %3A2334524
Re: esp8266 esp-01
I think the specific ask on this was that it either had to have or could be updated with the AT command firmware - not all those boards on ebay can be used that way - although there are some on there I found that look promising
