ULA1 nextgen idea...
Nasta
Re: ULA1 nextgen idea...
Post by Nasta »
OK, this needs to step back a few steps - are we talking about an ULA1 pin-to-pin replacement or a new chip or board that goes into new hardware (new motherboard etc...)? Asking because a good definition is needed or the thread title might be misleading. If it is a compatible replacement, a refresher on how it connects into the rest of the motherboard circuit may be in order, the QL iss6 schematic with all corrections can be found here:
http://dilwyn.theqlforum.com/docs/hardware/QLissue6.pdf
Can you define what ULA1 and ULA2 is?
Nasta
Post by Nasta »
ULA1 = ZX8301 ULA chip (Video and RAM control)
ULA2 = ZX8302 ULA chip (I/O, RTC, IPC comms)
Hi
Thank uou for the clarification.
I always wondered if ULA1 could be replaced with a new ULA with faster ram, this would only be used for Video Ram.
The idea was to eliminate the ram contension on the QL Board.
This all sounds what I meant...
But you said it is not a QL anymore...
I have PCs, Amigas, Atari STs, Spectrums, ZX81s and many more...
The QL is the operating system, not the hardware it runs on.
If you impose the limitations of a the sole of the QL is a 128K with expansion to 640K, twin 100K MIcrodrives, QL Network, then nothing moves on.
I can write the same programme in Superbasic, Assembler, on a QL with 128K ram bulit in 1984 and run the same programme on a Q68 that was built in 2020.
I believe that is what is known as an illustration - that the same program could be written on original hardware - new hardware platform and probably on the myriad of emulators out there - it was an illustration of what a QL is from a software layer perspective.
With regards to the topic itself - we started off talking about a possible enhanced but potentially plug in replacement for the ZX8301 - then it went off into I don't know what...
With this particular chip being prone to damage from plugging / unplugging monitors on the fly, and also from the fact that monitors that support the old broadcast scan rate with the QL's perverse timings for front and back porch, etc - it would be good to see if a plugin replacement - possibly offering more video modes, could be made that would drive VGA/HDMI directly, not be prone to damage when lived plugged could be developed.
My apologies for distrcting the thresd awy from the original topic.
Let me know when you have a working proto-type.
....now back sleep.
Brane2 wrote:
WRT HDMI, I remmber seeing some serializer for it (NXP?), but can't find it now...
Seen a couple of these - black something rings a bell - I have details at home - I will post it when I get back - was based on a lattice FPGA I believe...
https://blackmesalabs.wordpress.com/category/fpga/
some potential video ideas here...
Nasta
Post by Nasta »
The original pinout of the 8301 limits things quite a lot, it would be interesting to define some ground rules of the project with this in mind... and then the general context, scope and limitations.
