QL emulation on Linux - is there anything mainstream ?
- mk79
Re: QL emulation on Linux - is there anything mainstream ?
Best native solution is probably https://github.com/SinclairQL/sQLux
Apart from that people run QPC with WINE or SMSQmulator with the JRE.
- XorA
- Site Admin
Interesting. I didn’t know SDL2 didn’t support 4K windows.Brane2 wrote:That one comes closest to working for me, thanks.mk79 wrote:Best native solution is probably https://github.com/SinclairQL/sQLux
But there is nothing to install - make doesn't have install option.
So I have just copied sqlux to local bin directry.
But hten the snag is that it can't read ~/.uqlxrc, since it hasn't installed any.
So i've copied sqlux.ini to ~/.uqlxrc and tweaked existing options.
It looks like sqlux doesn't uderstand many of the default options from its own sqlux.ini/uqlxrc file.
After playing with that, I'm now at the point, where it almost starts with an error:
using Minerva ROM
Patching Boot Device mdv1 at 0x83ca
Video Driver wayland xres 3840 yres 2160
SDL_CreateWindow Error: Window is too large.
As for .ini file it understands all the options in the one in repo.
- Derek_Stewart
I use Linux Mint 19.3, which I have all QL emulators running:
Wine: QPC2, Qemulator, Qlay
Java: SMSQmulator
Compiled Linux: UQLX, sQLux
Dosbox: QPC1
UQLX sQLux, were compiled from the source code, with all depenancies satisfied, on Mint Linux and Raspberry Pi.
The Wine platform for QPC2 is very stable and with SMSQmulator is my main QL emulator use.
Java: SMSQmulator
Dosbox: QPC1
Nothing is secure attached to the internet so if you want 100% secure you don't connect. The internet is irrelevant to the QL anyway so the obvious path is use a separate disconnected machine for QL emulations work.Brane2 wrote:If it doesn't run wayland, it's useless to me. With all those government-funded crews rummaging around, anything non-hardened,non-selinux, non-wayland is useless.
- Derek_Stewart
HI,
i looked at Wayland a while back, but did not fancy thecwork involved in getting a working system running.
But on saying thst, I will have another look at it.
What do you recommend?
I domnot like Reddit...
- Derek_Stewart
I think Gentoo is not for me.
- XorA
- Site Admin
Feel free to put in a github PR for that, or Ill incorporate it when I get round to it.XorA wrote:Brane2 wrote:Errrm, WRT to sQLx, I managed to patch it to work now for me with wayland.
If anyone is interested:--- a/SDL2screen.c
+++ b/SDL2screen.c
@@ -62,6 +62,7 @@
if (sdl_video_driver != NULL &&
(strcmp(sdl_video_driver, "x11") == 0) ||
+ (strcmp(sdl_video_driver, "wayland") == 0) ||
(strcmp(sdl_video_driver, "cocoa") == 0) ||
(strcmp(sdl_video_driver, "windows") == 0) && sdl_mode.w >= 800 &&
sdl_mode.h >= 600) {
uQLx has no SDL support so that won't help!I haven't tried it, but probably the same fix should be applied to uQLx and during configuration, uQLx probably has to be configured with--enable-sdl2
- XorA
- Site Admin
Arse, something is wrong with the forum, I did not mean to delete your last post Brane2!
- NormanDunbar
- Forum Moderator
Oh dear! Whatever next I wonder?brane2 wrote:On top of that, air-gap won't help you with the stuff like EMI scan of your equioment and sniffing your parssword off your brain through RF:
