Tracking programming - File Management
spkr
Brittle Membrane
Post by spkr »
Hi there guys,
I would like to code out a (Music) Tracker for the QL. So Ill make a program that allows the user to define instruments by settings its parameters in the Tracker, and then subsequently arrange these instruments in a sequence that can be played back. The end result would be something that can be played back in another program (Demo, anyone :)).
In order to be most useful, I would like to implement loading instruments/patterns/songs and saving them. But so far Ive only worked on single-file programs, that are loaded and run from basic, and then executed; rather than touching filemanagement at all.
The goal Im trying to achieve here is to support (creating/)saving and loading files to/from (micro)disk.
To do this, I have several questions;
- generic: is there anyone that cna point me towards resources as to how to do this from Assembly?
and more detailed:
- can create/loading/saving Basic/OS functions be called from ASM?
- can this be done while in supervisor mode?
- can this be done while having interrupts disabled?
Hopefully someone is able to provide me some pointers!
Thanks!
Wietze
ppe
Re: Tracking programming - File Management
Post by ppe »
spkr wrote:Hi there guys,
Norman's Wiki pages have a ton of useful examples, e.g. http://qdosmsq.dunbar-it.co.uk/doku.php ... rap_2:open
His assembly language book is excellent:
https://github.com/NormanDunbar/QLAssemblyLanguageBook
Hope this helps,
Petri
Petri wrote:Norman's Wiki pages have a ton of useful examples, e.g. http://qdosmsq.dunbar-it.co.uk/doku.php ... rap_2:open
And if you get stuck, just give a shout out here, someone (or something!) will help.
Something?!? Is the tame QL Forum bot trained to give assembly tutorials? :o :D
I might be!
spkr
Brittle Membrane
Post by spkr »
here a preview of the tracker, currently load and save stuff still need to be implemented
http://frummel.org/~weedz/atari/examples/fuql_v05.zip
- known bug(s), on real hardware, at certain startups the screen stays black
spkr wrote:here a preview of the tracker, currently load and save stuff still need to be implemented
I tried this on Qemulator with Minerva v1.98, works great.
Are you looking to enhance the programme?
Must it be a "CALL" program? No chances to make it as a Job to EX?
spkr
Brittle Membrane
Post by spkr »
Well, it requires some more work; yes :)
spkr
Brittle Membrane
Post by spkr »
RalfR wrote:Must it be a "CALL" program? No chances to make it as a Job to EX?
I use supervisor and shut down all interrupts. So I guess the answer is yes it should be, no it wont be made to run as a job.
