libcurses keycodes wrong?
Another day another curses bug, the keyboards listed in curses.h seem to be wrong for at least backspace and cursor keys.
Here is the patch I plan to push to my repo unless someone screams its obviously wrong (and explains why).
Subject: [PATCH] INCLUDE_curses.h : correct keycodes
BACKSPACE
LEFT
RIGHT
UP
DOWN
all appear to be wrong in the file.
Signed-off-by: Graeme Gregory <graeme@xora.org.uk>
INCLUDE_curses.h | 10 +++++-----
1 file changed, 5 insertions(+), 5 deletions(-)
diff --git a/INCLUDE_curses.h b/INCLUDE_curses.h
index cf56f49..48262ce 100644
--- a/INCLUDE_curses.h
+++ b/INCLUDE_curses.h
@@ -80,12 +80,12 @@ typedef unsigned long chtype;
#define ACS_BLOCK (_acs_ch['0'])
#endif
#define KEY_BREAK 0401
-#define KEY_DOWN 0402
-#define KEY_UP 0403
-#define KEY_LEFT 0404
-#define KEY_RIGHT 0405
+#define KEY_DOWN 0330
+#define KEY_UP 0320
+#define KEY_LEFT 0300
+#define KEY_RIGHT 0310
#define KEY_HOME 0406
-#define KEY_BACKSPACE 0407
+#define KEY_BACKSPACE 0302
#define KEY_F0 0410
#define KEY_F(n) (KEY_F0+(n))
#define KEY_DL 0510
2.30.2
Re: libcurses keycodes wrong?
I might be wrong, it happens, but your 32 bytes might be the USB communications -- if your keyboard is or emulates USB of course.
I hate to put an end to another pointless discussion, but QL doesnt have USB or Wayland!
XorA wrote:Here is the patch I plan to push to my repo unless someone screams its obviously wrong (and explains why).
Thanks for spotting this. But how can the patch make it's way to where the C68 library is usually downloaded?
XorA wrote:I hate to put an end to another pointless discussion, but QL doesnt have USB or Wayland!
I knew that! :D Brane2 was talking about Linux, so I'm assuming he's using an emulator.
When I push it Ill prod Dilwyn and he will likely put it on his page in C68 section.
the full file in QL compatible zip I mean!
XorA wrote:
XorA wrote:
Peter wrote: Thanks for spotting this. But how can the patch make it's way to where the C68 library is usually downloaded?
Remember to "prod" me when it's ready, or I'll only forget :oops:
NormanDunbar wrote:I might be wrong, it happens, but your 32 bytes might be the USB communications -- if your keyboard is or emulates USB of course.
Sounds likely. USB keyboard report packets can be up to 8 bytes in size (containing up to 6 scancodes), but some implementations use only the first three or four bytes. In that case, modifier key status comes first, then a reseverd byte, then one or two scancodes. (Beware scancodes differ from PS/2 - otherwise a QL implementation for USB keyboards would be a little easier.)
The codes do appear to be the same as the ones in Linux
#define KEY_DOWN 0402 /* down-arrow key */
#define KEY_UP 0403 /* up-arrow key */
#define KEY_LEFT 0404 /* left-arrow key */
#define KEY_RIGHT 0405 /* right-arrow key */
#define KEY_HOME 0406 /* home key */
#define KEY_BACKSPACE 0407 /* backspace key */
So I am assuming the include file is a direct copy of unix version and not been adapted for QL
