Microdrive Label Template
mselkin
Post by mselkin »
Hi everyone,
I don't suppose anyone has a template to create/print microdrive labels?
It would be great to print labels on inkjet sticker paper.
If there is QL software to do that, that would be fun too!
Mark
dex
Re: Microdrive Label Template
Post by dex »
I hope this PDF file will work:
mselkin
Post by mselkin »
Thank you!
dex wrote:I hope this PDF file will work:
I downloaded it - but I cannot open it. Adobe Acrobat says that the file is damaged.
dex
Post by dex »
OK, try this one.
Contains templates for microdrives as well as for floppies.
Made by Louis Seidelmann 2011.
Microdrive cartridge sheet 2.pdf
(108.04 KiB) Downloaded 304 times
dex wrote:OK, try this one.
I didn't read your comment initially when eagerly opening up the PDF and was like "wow, that's a big cartridge." :-)
