I want a diskinterface without RAM - ie Spem if or Silicon Express if - must be OK.
I will swap a Miracle Trump Card 768 Kb fully functional.
It is because lack of space!!! And I got the RAM in my Qubide if.
Regards
Send me a PM, if interested.
Disk if - without RAM
- klausfrank
- Chuggy Microdrive
Re: Disk if - without RAM
It sounds you need one with a through connector (do these exist?)? Or are you using a backplane?
- klausfrank
- Chuggy Microdrive
Hi tofro,
Well, I should have told more, but you are right, I have a backplane, - the case I am using is a Spem System 2. I cannot use the Trump Card, it is too heavy, therefor I want to swap interfaces.
Regards
Regards
I have a Sandy SuperQ Mouse board, no ram just FLP controller: PM your address and I will post off to you to try out.
