Software development on BBQL
I've been doing work on my ZXSimulator and have been using my unexpanded QL with vDrive and it actually works reasonably well. The compiles aren't bad (I have it split into 4 C modules so I only need to recompile 1 or 2) and the linking takes a bit of time (vDrive slows things down). But editing with QED is nice and I can live with the compile times. Kind of neat to see the work one could do (and I actually did) in the 80's and early 90's with the QL (esp if you had a floppy instead of micrrodives).
When I first developed the ZXSimulator I used an emulator to modify my original prototype source but I decided I'd finish it (add floating point and fix DIM for arrays -- working on the latter now) on my BBQL. Why am I a glutton for punishment? It's a hobby and kind of cool to see how seamless Digital C SE lets you do it. It's not a bad environment to work in. I sometimes use ICE and on many occasion I just revert to the command line. There's also an excitement when your code has fully linked and you run it...I guess because it took a few minutes to complete :)
