I want to use a gotek 720K as a floppy with my trump and gold card. Is there a specific model?
Michael
Gotek 720K
Re: Gotek 720K
I suggest to refer to the link below, and choose one of the FlashFloppy compatible models.
With about 10 € you may buy a compatible Gotek and easily install the FlashFloppy firmware, which allows to handle not only the normal 720K floppy images, but also the GoldCard 1,44 and even 3.2 MB ones
https://github.com/keirf/FlashFloppy/wi ... patibility
Re: Gotek 720K
Hi to all.
A question. Is it possible to make a bootstrap of the Ql from an image of the Gotek, containing obviously a boot file?
Thanks to all those who want to answer me.
Best regards.
Best regards.
Re: Gotek 720K
Well, the files you'd store on the USB drive you put into a Gotek are merely pure images of the contents of a floppy disk, as you would use with "rawwrite.exe" on a PC*.
I'm not sure what you mean by "bootstrap". If you want a set of images on the USB drive then you have to create the empty files of the correct size first and then you can select them on the Gotek and format them from the QL as if they were a normal floppy disk.
* Other raw disk image read/write programs are available and vary between platforms.
Re: Gotek 720K
Hi Tesla,
whatever you can do with a real floppy, can be done with Gotek. The QL cannot distinguish between Gotek and a real floppy drive.
Re: Gotek 720K
Thanks to Stephen and Cristian for yours answers.
For Stephen, with bootstrap I meant the normal starting of the Ql from a boot program.
Ciao.
Ciao.
