Hi all
Just wanted to introduce myself to the forum. I recently got a QL up and running having always wanted one when I was a kid (back in the 80s)
Next I need to try and fix the Microdrives
Ian
Hello from the North West
- Sparrowhawk
Re: Hello from the North West
Hello and welcome. Seems like there are quite a few people getting a QL for the first time and finding their way here, which is great.
a.k.a. Jean-Yves
Welcome to the forums - the main issue with microdrives is the felt pad on the cartridges themselves disintegrating.
Next to check is
a) the tape head - clean it with some tap head cleaner
b) the rubber roller on the left hand side of the slot - has this ridden up the metal post it is on (there should be a 0.2mm gap at the bottom - press it onto a piece of card and remove the card)
c) Has the rubber roller worn - normally the top half - if so, turn it upside down!
d) The microdrive ULA may be damaged - these are a real pain to replace!
Next to check is
I think its fans of retro computing like me finally getting the computer they wanted at school.
I am running a user group meeting in September and will have the QL on display so should get some people interested (that's if I ever get the Microdrive working!)
Details:
http://thedigitallifestyle.com/w/index. ... mber-2012/
Details:
Welcome to the Forum Ian!
Where in the North West are you? I'm over in Ormskirk.
- vanpeebles
- Commissario Pebbli
Thanks for the tip on the Microdrive, the 2nd drive works some times and both seem to spin ok so I think the next thing to do is to clean the heads.
I am in Chorley so not to far from Ormskirk and the user group event is just off the a580 in Wigan, maybe you could come and bring your QL
