Found these in my QL "junk box". I thought they were QL feet at first, but they don't fit a UK QL at least, they seem to have clip-in fastening rather than the push fit rings of the UK QL ones. Wonder if they could be for Samsung QLs, as I know some QLs had different fittings for the plastic feet?
The brown residue on them is brown parcel tape adhesive, which should clean easily enough. If they are any use to anyone, you are welcome to them.
What are these?
Re: What are these?
Yes, they're for Samsung QL's.
I could make use of them as I have at least one Samsung QL sans feet, which is a bit annoying (esp as the other feet don't fit).
Re: What are these?
OK, PM me the address to send them to, I'll send them once I've figured out any customs paperwork if sending to Germany.Chr$ wrote:Yes, they're for Samsung QL's.
I only have two of the feet - don't know if the Samsung QLs had two or three feet.
Re: What are these?
Oh, those aren't air vents...I actually have my feet somewhere but have never used them. Don't need the QL to be even higher off the table
Re: What are these?
Can confirm this is the style of feet issued with German and US QLs. They positively attach and don't fall off.
