Hello,
I bought on sell my retro the tetroid interface with the compact flash ...
everything works fine ... but when I turn on the ql and it starts up with the tetroid interface which is connected ... after a few seconds the pointer environment is displayed perfectly ... but alas, I have not how to use this pointer environment ...
where can I find the user manual of the pointer environment of the tetroid interface
thank you very much .. excuse me for my english .. i'm french (bordeaux)
best regard
bye Bye
didier
tetroid interface and system environment pointer
Re: tetroid interface and system environment pointer
Try looking at the QL Homepage for documentation for the Pointer Interface:
http://www.dilwyn.me.uk/docs/ptr/index.html
I remember the hardest thing I found when my TDI was new was where the Start Menu came from and how to configure it! Had no idea that it was Qascade that makes the Start menu and nothing to do with QPAC1/2... I know the boot file gives lots of clues, if you know how. But there is much learning.
So do read up on the PE etc, but for starters, all the things in the 'Start' menu are structured/defined in a file called qascade_rc.
HI,
There is a help file that accompanies Qascade, which details the creation of the menu and the way a custom menu can be used.
Qascade is a PE or to give the correct name Extended Environment application that uses a pointer to select application detailed in the QASCADE_RC file or custom menu specified in the startup command line.
