as68 error message
swensont
as68 error message
Post by swensont »
As I'm converting all non-curses print calls to curses one, I've hit a snag on the program that I am porting.
Everything was compiling fine with Make. I found a few minor issues with main_c. I fixed the last error and now I get this message:
as68 main_s main_o
jas: (bytes not separately relocatable)
I can't find any documentation on as68, so I don't know what that means. I made no changes to the Makefile. The c compiler seems to like the code as it does not report any errors. I'm hoping someone has a clue what this message means.
Tim
swensont
Re: as68 error message
Post by swensont »
Looking at the as68 source code, there are a couple of ways to get this message:
if ( havebyte == 1 && rval != orval )
if ( rval != R_ABS && rval != R_FIRST )
None of those look obvious as to what the problem is. Hopefully someone else has seen this and knows the solution.
Tim
Looks like it might be caused by access a word on odd byte boundary!
ppe
Post by ppe »
XorA wrote:Looks like it might be caused by access a word on odd byte boundary!
Unaligned struct member, perhaps?
Curious that it doesn't say a line number along with it. A few options, revert your changes in main_c and re-apply them, always checking when the error appears. Or have a look at main_s if something is fishy. I don't think its got anything to do with alignment. More some pointer usage problem (that the compiler accepts but is still wrong) or a weird name-clash.
