QL S*BASIC tracker
EmmBee
QL S*BASIC tracker
Post by EmmBee »
Hi all,
I have written some code that takes the currently loaded program and adds in tracking information - the tracker reports on routines called, where from, values of arguments and return values.
Execute the tracker_task;
The new program gets created as ram1_tracker_prog – so load this anew.
The first four lines may need editing.
 1.	_log$ = "RAM1_tracked_rpt"       The report file that will be created
 2.	_max_file_size = 800000          Maximum file length before being overwritten from start
 3.	_tstep = 2                       Indent number of spaces between routines
 4.	_chan = 14                       Required # channel number for the tracker _log$ file
From here on the program acts like the original.
tracker.zip
(48.38 KiB) Downloaded 151 times
