C68 File extensions
C68 File extensions
I read in the C68 manual, that the compiler converts the .c separater to a underscor _c
file.c becomes file_c
But if there us a file to be included, e.g. header.h, with the statement:
#include "header .h"
where the file is located in the current directory.
The cc programme can not find the the file until the file is renamed to header_h
Is there a command to overide the separator conversion, as I can not find it in the manual.
EmmBee
Re: C68 File extensions
Post by EmmBee »
Derek_Stewart wrote:Hi,
Hi Derek,
If we are talking about unzipping files using the QL version of unzip,
then the default action is to use all underscores file_c header_h etc.
There is, within unzip, the option -Q1 which will unzip using all "." dot extensions: file.c header.h etc.
Which particular C68 manual are you reading ?
EmmBee
The section is: C68 GNU Preprocessor, Section 2,2
But I have just found the detail that I need, which is in the C68 environment on QDOS and SMS, regards Automatic Handling of Foreign Filenames.
Looks like I did not read the manual enough.
