QL USER type-in programs
INSTANT SPRITES - published in QL USER April 1985
PENTATHLETE - published in QL USER November 1985
The archive contains a mdv image with the programs.
Pentathlete was a effing pain in the back to scan, OCR and correct as it was printed with very small characters.
There is a bug in Event 3 - the javelin in flight is not erased from the screen - but that is how the code was printed in the magazine.
QL_USER.zip
(20.31 KiB) Downloaded 213 times
Re: QL USER type-in programs
Would you please also supply a standard ZIP with the files. Thanks.
Allow me... here's a standard qzip.
QL_USER.zip
(15.93 KiB) Downloaded 228 times
Thank you :)
Fixed a bug in Pentathlete_bas
line 32060 should be GO TO 10
(I hate GO TOs in Superbasic programs!)
qluser.zip
(15.93 KiB) Downloaded 237 times
QL_USER_MDV.zip
(37.74 KiB) Downloaded 204 times
GOTO?
Really? Is there anything more genuinely vintage?
We advance on vintage but in our own way.
Dave wrote:GOTO?
If you really do not know this keyword, simply look at the SuperBASIC source of the Tryptich collection and/or QL.Gardener... They were genuine experts in using it.
:D
stevepoole
Post by stevepoole »
In the early days of computing, people relised that programs could be almost excluseively written using just IF and GOTO Label !
They soon realised the need for more intuitive structures....
Even now, when I translate SuperBasic into ProPascal, some instances of GOTO cannot be avoided. (SB 'Loop epilogues' etc ).
Sometimes, an occasional GOTO can avoid a lot of acrobatic structuring, and is clear enough to follow.
So don't throw the baby out with the bathwater.
Steve.
I believe that there is no need for GO TO - you can use structure your program and use procedures and functions.
And I am not sure that you can compile a program that uses GO TOs (probably not)
Andrew wrote:I believe that there is no need for GO TO - you can use structure your program and use procedures and functions.
Programs with GO TOs will happily compile - so long as they are not computed GO TOs - the bane of all programmers!
The original D-Day and War In The East showed classic examples of both GO TO and GO SUB (many of which were computed values) - mixed in with code which was never actually called - it was obvious that the programmers had ideas in D-Day in particular, but never got them working. For D-Day MKII and War In The East MKII, I re-wrote the vast majority of the programs converting it all to procedures and functions before I could determine the best bits to convert to machine code.
