Thought this would probably be best for the 'wanted' section.
I have some original QL games/software twice, so instead of selling them I'd quite like to swap them for ones that I don't already have if anyone's up for it. Worth a try...
To swap I have the following:
QL-Chess (Sinclair branded pack, missing card outer).
Chess (same as above but later Psion branded version, everything present).
NO LONGER AVAILABLE: The Lost Kingdom of Zkul 30/9/20 no longer available.
Match Point (missing instructions).
Cartridge Doctor (missing instructions, again).
And a couple of scarcer ones...
NO LONGER AVAILABLE: Karate (all fine, fairly hard to find) - 14/9/20 Karate no longer available.
Star Guard and Galactic Invaders (missing original instructions but comes with nice printed replica instructions, very hard to find).
I'll supply all of the above with duplicate working re-felted cartridges containing a copy of the original and will also send an mdv image for emulators/vDrive.
Rather than listing all that I don't have, please simply pm any swapsies, or post here if you can't pm.
Original QL mdv Swapsies.
Re: Original QL mdv Swapsies.
I want Zkul and Star Guard - I will have to check what duplicates I have and send you a list.
Ok. Over the last few months I've had 3x Zkul in various lots (sold the 3rd), it seems to be a common one... unlike West, which was hard to find and the one I did find is missing its instructions.Andrew wrote:I want Zkul and Star Guard - I will have to check what duplicates I have and send you a list.
Update - Karate is no longer available.
