Are these
https://www.comtecdirect.co.uk/product/ ... 31a/PG1115
the proper plugs?
I don't have my UK QL at hand, so can't check. The left hand ones are marked as "Clearance".
BT Plugs for Joystick and Serial
Re: BT Plugs for Joystick and Serial
A-type has the wrong keying groove (I think I read that they be adapted with a knife). W type is correct:
https://zxnet.co.uk/spectrum/btconnectors/
Also, those that begin with a 4 only have contacts for 4 wires.... perhaps that could also be changed by adding 2 contacts from another plug. Might be worth a try.
This rang a bell so I looked at my 25 way RS232 leads I made many moons ago and I had scraped the plastic to make them fit. I will just add to the above that when looking at the back of the QL you need 6 connections with pins facing down and latch on the left for the serial ports but latch on the right for the two joysticks assuming I am not dyslexic.Chr$ wrote:A-type has the wrong keying groove (I think I read that they be adapted with a knife). W type is correct:
spot on - well rememberedRuptor wrote:This rang a bell so I looked at my 25 way RS232 leads I made many moons ago and I had scraped the plastic to make them fit. I will just add to the above that when looking at the back of the QL you need 6 connections with pins facing down and latch on the left for the serial ports but latch on the right for the two joysticks assuming I am not dyslexic.Chr$ wrote:A-type has the wrong keying groove (I think I read that they be adapted with a knife). W type is correct:
I remember the joystick ones being hard enough to get in the 80's
I have parts to make QL Jotick to DB9 cables, I will see if I can get these QL Joytick Cables made and posted for sale.
Hi everyone!
I recently trawled the web looking for both these two BT-style plugs and found a reasonable-cost supplier of both.
I myself ordered a small batch of the QL Serial type (BT-631W) and inquired of the same supplier whether they could source the Joystick variety (BT-630W), which wasn't shown on their site at the time.
The supplier since confirmed availability of the 630W and has now added it to their website.
I'm not associated with this supplier in any way, though I was happy with their service myself - Derek and our other in-house hardware suppliers will have more experience/advice, but thought to share their details here:
BetterBox: https://www.betterbox.co.uk/
BT-631W (QL Serial) (part code CT6310): https://www.betterbox.co.uk/products/bt ... t6310.html - £1.95 exc. VAT
BT-630W (QL Joystick) (part code CT6300): https://www.betterbox.co.uk/products/bt-630w.html - £2.15 exc. VAT
M.
M.
Excellent. That is quite expensive though, isn't it (I feel). But with limited availability I suppose they can charge what they like.martyn_hill wrote:Hi everyone!
M.
Another related question, perhaps you know the answer: The crimping tools that are available for attaching wires to the BT type connectors are usually advertised as being for the 631/431 type plugs - they will handle plugs with either 6 or 4 connectors. Looking at pics of them, they appear to have spaces for the clicky tab on either side so can you (or someone else) confirm that the crimping tools advertised for 631/431 can be used with all types of plugs including the other-handed 630W/630A?
When I looked at my RS232 leads I remembered I bought this
https://cpc.farnell.com/pro-signal/3100 ... g%20bt630w
chopped the lead in half giving two ready crimped plugs and scraped the plastic to make the A type fit the W hole. I like a cheap botch.
Hi Chr$ and Ruptor!
Yes, expensive for what they are - one of the reasons I shared the details was the possibility that, if we as a community (via one of our dedicated hardware gurus) were to place a bulk order - satisfying our collective needs for the foreseeable future - we may be able to secure a much better price-point.
I picked-up 10 of each, just in case I never find another vendor for such EOL product-lines...
Chr$ wrote:Excellent. That is quite expensive though, isn't it (I feel). But with limited availability I suppose they can charge what they like.
Not sure, but like you, suspect that the crimper will take both handed plugs...Chr$ wrote:Another related question, perhaps you know the answer: The crimping tools that are available for attaching wires to the BT type connectors are usually advertised as being for the 631/431 type plugs - they will handle plugs with either 6 or 4 connectors. Looking at pics of them, they appear to have spaces for the clicky tab on either side so can you (or someone else) confirm that the crimping tools advertised for 631/431 can be used with all types of plugs including the other-handed 630W/630A?
