QD vB.07
- mk79
QD vB.07
I uploaded a new QD version to https://www.kilgus.net/smsqe/qd/. It finally seems to fix the crashes Per experienced with it (thanks for isolating the problem!). Basically it could corrupt memory if you give it an editor height on the command line (e.g. "\n200") that does not fit on the screen. I introduced the bug in B.05 while implementing the per-extension file usage feature, a very unfortunate and unexpected side-effect.
Cheers, Marcel
Cheers, Marcel
Re: QD vB.07
Hi Marcel,
Great work.
I use QD for assembler programming and I am using QD more for Basic programming.
Just a couple of questions:
1) The Usage for Basic only highlights the DEF PROCedure statements, is it possible to have full syntax highlighting
2) How to compile with Qliberator from QD, at present,I have to save the basic programme with line numbers and compile from Sbasic. Can the QD basic programme be sent to the Qliberator Thing and compile it that way?
Great work.
Re: QD vB.07
@Derek: JMS used to sell a product called QBASIC which was similar to the SBAS/QD Thing except it would send the file being edited in QD to Q-Liberator rather than SBASIC. Personally I didnt like it, partly because you couldnt have both SBAS/QD and QBAS/QD at the same time; it was either/or.
So, naturally, I wrote my own version, which works via FileInfo2 to compile line-numbered or numberless (or _sav files) directly from a file manager (like QPAC2 Files). I find that much more practical.
Re: QD vB.07
@mk79:
Thanks for fixing and maintaining QD!
Ive tried the rest; QD suits me best!
- mk79
Re: QD vB.07
In theory yes, of course, in practice no. I tried once 10 years ago and failed. The code is not really prepared for these kind of things.Derek_Stewart wrote:1) The Usage for Basic only highlights the DEF PROCedure statements, is it possible to have full syntax highlighting
No idea, but I have uploaded the QBASIC thing Per mentioned, in case anybody has a use for it.2) How to compile with Qliberator from QD, at present,I have to save the basic programme with line numbers and compile from Sbasic. Can the QD basic programme be sent to the Qliberator Thing and compile it that way?
Marcel
Re: QD vB.07
No, you have just uploaded the QD Manual.PDF. Perhaps the wrong link.mk79 wrote:No idea, but I have uploaded the QBASIC thing Per mentioned, in case anybody has a use for it.
Re: QD vB.07
Hi Marcel,
I tried to download QBASIC.ZIP and got the QD 2018 Manual.
But with regards to compiling with Fileinfo2, I think a possible approach is:
Start SBASIC
Load basic programme to be compiled
Create Qliberator work file by LIBERATE dev_filename_ext
quit SBASIC
EX qlib_obj;"dev_filename_ext -OBJ dev_filename"
My first attempt at this did not work.
Start SBASIC
quit SBASIC
- mk79
Re: QD vB.07
Argh, copy&paste is evil. Fixed.Derek_Stewart wrote:I tried to download QBASIC.ZIP and got the QD 2018 Manual.
Re: QD vB.07
I think QBASIC's parser is written by TT, I once have gotten a program "parser" from him to try. This could it be.
But the more serious question is, if the parser is able to control nowadys SBASIC?
Re: QD vB.07
The download works perfectly, so I should be able to compile SBASIC programmes from QD.
I could configure Fileinfo2 to use a version of QD with different Thing option in the command line to use SBAS/QD or QBASIC.
As for the Syntax colouring, I do not think this a problem.
Anyways, Microemacs has a Hilite mode
