QL VGA Boards
Sell your QL items here!
QL VGA Boards
Marcel has asked me to deal with the marketing and distribution of his QL-VGA boards.
They are also suitable for the Spectrum +2 and Spectrum+128 :)
£70 + shipping each (including VAT).
https://www.sellmyretro.com/offer/details/45023
Re: QL VGA Boards
Quantity Available 0
:D
Re: QL VGA Boards
Well, that was fast :)
Re: QL VGA Boards
I am guessing there may be another run if these are popular (and they probably will be) ?
Re: QL VGA Boards
I'm working on a single-board successor that hopefully can be manufactured in slightly bigger numbers as for this run much hand-soldering was still needed. Design is ready, but I have to postpone ordering a prototype because of my upcoming holiday. If that works (and that is quite some "if" as that is by far the most complex board I have ever designed) then it can be manufactured on a bigger scale.
Re: QL VGA Boards
mk79 wrote:I'm working on a single-board successor that hopefully can be manufactured in slightly bigger numbers as for this run much hand-soldering was still needed. Design is ready, but I have to postpone ordering a prototype because of my upcoming holiday. If that works (and that is quite some "if" as that is by far the most complex board I have ever designed) then it can be manufactured on a bigger scale.
Go for 1,000! ;). Alright, perhaps not 1,000. But if they also happened to be a bit cheaper as a result of that (I know I keep going on about it) you'd shift 100 easily.
And it was good to see them readily available online for people to buy - at least it was until they sold out.
Einen schönen Urlaub!
Re: QL VGA Boards
Yes 100 would be easy to sell, as they also appeal to Spectrum+128 and Spectrum +2 users. Not managed to try one on a Spectrum+2A/+2B or +3 mind!
Re: QL VGA Boards
I tried one on a +2 grey, works a treat.
Re: QL VGA Boards
RWAP wrote:Yes 100 would be easy to sell, as they also appeal to Spectrum+128 and Spectrum +2 users. Not managed to try one on a Spectrum+2A/+2B or +3 mind!
+2A/+2B and +3 have analog video output and are therefore not compatible. QL-VGA expects digital TTL signals as input, only 128 and +2 have that.
Storycrafter
Re: QL VGA Boards
Post by Storycrafter »
As does Commodore 128, although it also uses the intensity signaling for additional, brighter colors (getting that right requires hacks).
