qubide single ended version what gal version ?
techy
Post by techy »
Hi forum ,
I am building a qubide single ended version (José Leandro clone ) and wondered what version of rom and gal's to use .
as the version on his website goes up to 1.56 and are dated 1997 and 1998 .
I saw a lot of newer developments , but are they suitable for the clone version or only qubbesoft original ?
OR , do you recommend another design ( smd free ) ?
Can someone please shine a light .
HAOUI
Re: qubide single ended version what gal version ?
Post by HAOUI »
You can use the QUbATA V3.10 Driver for the Clone version.
I attached below the archive containing ROM and GALs binary codes to burn.
There is also a REXT code which can be LRESPRed after having configured the base address for QubIDE hardware.
Alain
QubCloneV310.zip
(821.15 KiB) Downloaded 376 times
techy
Post by techy »
Anyone a good source for the ;
74hct646 ??
the prices overhere are sky-high , € 15,- for one piece !!
WILL a 74ABT646 be suitable as a replacement ??
techy
Post by techy »
@ HAOUI ,
Thanks for the files
the 74hct646 should be available on ebay - for 2 off quantities.
Do you have something like festo / RS / Farnell there?
Also - does the version you are building have the surface mount version or the dip version of this chip?
techy
Post by techy »
Pr0f wrote:the 74hct646 should be available on ebay - for 2 off quantities.
the version i am working on has the smd version , if a through hole version is available please let me know .
if the other chips are all through hole, then this is the same version I have built - only those 646 chips are surface mount - one on one side and one on the other side of the pcb
techy
Post by techy »
yep , only 2 smd's ( that is more than enough for me )
only finding them is a pita ..............
hence my question for equivalents .
https://ebay.us/XrDrfI
those should work
techy
Post by techy »
Pr0f ,
you are right , there are more sources , the big electronic suppliers and some enthousiasts on market sites.
i verified prices , and apparently i live in a country which is expensive to sent to .....
shipping varies from around € 15 to € 25 ( rs ) , which is a "bit" over my budget for 2 "penny components "
the search goes on in that respect
