How to uQLx on RPi
How to uQLx on RPi
More stupid operating system questions I am afraid. I downloaded the RPi uQLx, followed the instructions to detar it that seemed to work, copied the Koenig config to home and run to get segmentation error. I have probably done something wrong but don't ask me what. Any ideas?
I am trying to run it on a zero if that makes any difference.
Is it Koenig or Konig?
- NormanDunbar
- Forum Moderator
Re: How to uQLx on RPi
Where did you download from? And what is the Koenig file you mention. I have a couple of Pi Zeros, I might be able to test.
Hi
I did get uQLx to run on a RPi - it was however a Rpi 3 & that was 4 years ago - see post http://qlheaven.blogspot.com/2016/03/uqlx-on-rpi3.html
But I have no idea about a Koenig file.
Cheers
Cheers
Why not compile sQLux on the RPI.
I have a spare RPI 3B, so could give it a try...
Dilwyn site and the config.txt files come out with the tar when unzipped.NormanDunbar wrote:Where did you download from? And what is the Koenig file you mention. I have a couple of Pi Zeros, I might be able to test.
Its the blokes name that wrote the instructions. Urs Konig or Koenig.Artificer wrote:But I have no idea about a Koenig file.
I can't even get a ready made system with simple instructions to work so you are not suggesting I should compile something from sources are you?Derek_Stewart wrote:Why not compile sQLux on the RPI.
Is nobody using the RPi?
The instructions say "3. Now you need to create a .uqlxrc configuration file (important the filename must start with a .)" but your blog implies the file shouldn't be so.
- NormanDunbar
- Forum Moderator
The file is indeed .uqlxrc, it must start with a dot, and one is supplied in the zip file.
On the Pi, do ls -a to see hidden files, those which start with a dot. That's "ell ess minus a" in case fonts cause problems.
You can "cat .uqlxrc" or, worse, "nano .uqlxrc" if necessary.
Thanks but I tried the file with and without a dot and still get segmentation error.NormanDunbar wrote:The file is indeed .uqlxrc, it must start with a dot, and one is supplied in the zip file.
The export command should also be in lower case not as in instructions.
If I have done everything correctly according to the instruction, which is not very likely, then the only change is Rasbpian that they now call RPiOS.
- NormanDunbar
- Forum Moderator
The Pi Zero is Arm 11, apparently. Maybe the Arm 7, 8 or 9 versions don't work? When I get time, I'll see what I can find out. I have Pi 1 (256RAMs), Pi 2, 3 and 4 plus a few zeros.
