SGC Power Supply
SGC Power Supply
What is the recommend maximum milliamps for the supergold card 5V power supply connection?
Re: SGC Power Supply
In my SGC supplement it makes no mention of amperage. As it will only take what it needs I suspect a 1A supply would probably be fine.lowrybt wrote:What is the recommend maximum milliamps for the supergold card 5V power supply connection?
Don't take my word though, see if someone else confirms that!
Good stuff, thanks for confirming Dave. Then 1A is plenty, even 500ma would do it. May as well chop up a USB cable, put a barrel on the end and use a USB to mains adapter thing - most of those seem to be at least 1A.Dave wrote:My SGC draws 320ma under load and 260ma idle.
