Qnet BBQL connecting to QXLII, probs
Hello.
I've moved my BBQL (Minerva and TK2) to the same room as the QXLII and am trying to get them to talk to each other over a QNET for the first time. The QXLII has a very basic QDOS QXL.WIN setup at the moment with just PE, QPAC2 and some other 'common' add-ons. The BBQL has a similar setup.
On the QXLII I enter 'net 1', then 'FSERVE' (or the other way round, both result in the same failure).
The BBQL I assign as 'net 2'.
And then I try to get a directory of the other machine by, e.g. 'dir n1_win1_' from net 2.
It thinks about it for less than a second and then reports 'net aborted' and on the line under that 'incomplete'.
Have I forgotten something important? I did have previous success with QNET between a BBQL and my custom cased QL with GC (and I'm using the same mono 3.5mm jack plug cable, so I know the that is good).
Re: Qnet BBQL connecting to QXLII, probs
Does the QL have TK2 in ROM? Otherwise it won't be able to talk to a file server.
tofro wrote:Does the QL have TK2 in ROM? Otherwise it won't be able to talk to a file server.
Yes, via it's TDI card (loaded via TK2_EXT in the boot file).
Fixed it! Feel foolish yet again... I cleaned the QXLII QNET sockets with ISO and a stripped down cotton bud, all good now.
