SMSQ/E and SMSQmulator
As Wolfgang isn't on this list AFAIK, I thought I'd copy his emails from the ql-users mailing list to here as a bit of software news.
SMSQ/E 3.35
SMSQ/E 3.35 is out now (wlenerz.com/smsqe).
The sources for the revised QL-SD drivers from Marcel Kilgus are in
there now.
There are also some bugfixes, including one which could cause the entire
acne to crash severely if a string variable was used as a REPeat loop
control variable (bug found by Per Witte).
As a result, it is no longer possible to use string variables as REPeat
loop control variables (just like FOR loops).
SMSQmulator 2.28
SMSQmulator 2.28 is out now.
(http://www.wlenerz.com/smsqmulator)
