QPC Print
kermit999
QPC Print
Post by kermit999 »
Hi, I have posted this question on Marcel's web page (contact me) quite a while back, but up to now I have not received any feedback from him, so, I'm hoping someone out there maybe able to help.. My question is:- Is it possible to use a wifi connected printer to get an output from QPCPrint ? I have read and studied the QPCPrint manual, but cannot find a solution. I am using a desktop PC running Windows 10, and with QPC2v4, also dabble with Qemulator & SMSQulator..
Re: QPC Print
Check your spam folder, I have answered 10 days ago. Wifi or not has nothing to do with it, either the printer works with Windows or it doesn‘t.
Re: QPC Print
I run it as a virtual printer (as described in the manual) via a Fritz!Box WLAN router, works perfectly.
kermit999
Re: QPC Print
Post by kermit999 »
sorry mk79.. Nothing in my IN tray or SPAM folder.. Any chance you could re-post your reply ... please
Re: QPC Print
My answer is above. It simply doesn't matter if the printer is Wifi or not. What's the problem?
