PSU Question - Better safe than sorry
Hi everybody!
I have received UK version of PSU unit for QL. I live in Europe (continental part), so my question is it safe to use UK PSU in Europe without any adjustments except changing electric plug?
Best regards,
Stevan Kordic
Best regards,
Stevan Kordic
- vanpeebles
- Commissario Pebbli
Re: PSU Question - Better safe than sorry
Yes, 220-240 V at 50 Hz.vanpeebles wrote:Are you 220/240 volts?
- vanpeebles
I'm trying to remember if the QL PSU has a live, neutral and earth.
My UK PSU has only 2 wires, I guess live & neutral.vanpeebles wrote:I'm trying to remember if the QL PSU has a live, neutral and earth.
HI,
The voltages are the same, so just put a EU plug on the end, or fit a UK-EU adaptor.
The UK Colours are:
Brown : Live
Blue: Neutral
Earth maybe not fitted.
The UK Colours are:
Brown : Live
Blue: Neutral
If there is a double square moulded or printed on the bottom of the psu where the label is, then NO earth should be connected - as that mark indicates the item is double insulated, and is isolated from mains earth - most of those early power supply models for home micro's fell into that category.
Thanks Derek! Yes, I will do so and I hope everything is going to work fine!Derek_Stewart wrote:HI,
The UK Colours are:
Brown : Live
Blue: Neutral
Best regards,
Stevan
Yes, there is a double square on the bottom of the PSU. Also, there are only 2 wires: blue & brown, no wire for ground. I will buy just a plug and connect it to the PSU.Pr0f wrote:If there is a double square moulded or printed on the bottom of the psu where the label is, then NO earth should be connected - as that mark indicates the item is double insulated, and is isolated from mains earth - most of those early power supply models for home micro's fell into that category.
Thanks everyone for the clarifications!
Best regards,
Stevan
The QL PSU has a transformer and is unswitched, so the live/neutral matter is moot and it really does not matter which way it is wired. It is a double insulated power supply, so no ground.
The 240V PSU will work without issue on 210V to 270V, 50-60Hz.
