PNG <-> SPR
Giorgio Garabello
PNG <-> SPR
Post by Giorgio Garabello »
We have 2 software for converting png images to spr (thanks to Wolfgang and Marcel) ...
But is there any software that does an opposite cover? (spr -> png)
Giorgio
Re: PNG <-> SPR
Not that I would know.
The simplest thing to do is run a sprite viewer on QPC and use Windows Snipping tool to grab the image as png. That's what I do in case I need a .png.
Artificer
Re: PNG <-> SPR
Post by Artificer »
Or us a QL program like EddIcon which is a sprite editor, load the sprite, and save it out as a .bmp file. Load the .bmp on a PC to a program such as irfanview and save out as a .png.
Cheers
Artificer
Giorgio Garabello
Re: PNG <-> SPR
It's not so simple :-)
Using your solutions I lose the transparency ….
Giorgio
