Not sure if you are all familiar with Playtapes? They were very small tapes, like 8 track, but about 1/4 the size. Still bigger than Microdrive Carts but closer than big 8 tracks.
Wonder if these could be used to re-felt our carts?
https://www.8trackavenue.com/product-pa ... -foam-pads#!
TJ
Playtape Felt for Microdrive Cartridges?
- SinclairSociety
- Trump Card
Re: Playtape Felt for Microdrive Cartridges?
The new (high density) felt needs to be 4mm long, 2mm wide and no more than 1.5mm high otherwise it'll put too much pressure on the tape.
