Does ny one have this set working?
I just got a brand new set of 10 disks, ACT works when you select from the menu. But when I choose 39 which is Professional Astrologer, it says insert disk 10, then I always get an error after formatting FLP2_ completes, then I get AT LINE 153 error in expression,
which is trying to save so code to FLP2_
153 SBYTES"FLP2_"&TTK$(n%),ADDR,6872
and its not just this program, the Perfection word processor when I try from the menu does the same thing, With that I just unzipped the perfection zip file and it works. When I do the same with Professional Astrologer you run it and its looking for EXTENSIONS_CODE and its not in the zip and the program won't run. Of course Extensions_code must add extols to superbasic that Professional Astrologer/Astronomer require
Anyone can help please ?
Thanks!
Bill
Digital Precision 10 Disk set
- Brittle Membrane
- Aurora
Re: Digital Precision 10 Disk set
What is the version number of disk 1?
There was some problem with versions before v4.0. I don't know exactly what the problem was, But I have a note form DP dated December 1994, implying extraction problems.
It says the new disk 1 has a yellow label, and briefly announces itself as Version 4.0 on boot up.
- Brittle Membrane
Martin,
The first disk has a yellow sticker on it that says NEW. I boot the disk and I dont see a version 4 and nothing in the boot files either.
Thanks
Bill
Thanks
Bill
I have sent Bill some other versions of the QL1 disk (neither had the yellow stickers, but both have different boot2 files) !
So far as I know, DP only ever issued an updated QL1 disk - so the problem with Professional Astrologer is odd - I have also sent Bill the Extensions_Code (thankfully it looks to just be the Turbo Toolkit) from the original Astrologer disk
