ADVENTURE CREATION TOOL Manual
Can anyone send the ADVENTURE CREATION TOOL Manual - in a format that I can use (pdf, word, Quill )
The manual that I have on the disk is in Perfection format - and I do not have Perfection.
I can open the manual as text, but there are a lot of Perfection formatting characters in it that makes it a bit hard to read (and a lot of work to edit it by hand)
Re: ADVENTURE CREATION TOOL Manual
There's a Perfection demo disk on Dilwyn's site that contains a runnable exe file.
Maybe that can help?
Might help to read it once, but not to convert it to a really usable formattofro wrote:There's a Perfection demo disk on Dilwyn's site that contains a runnable exe file.
Hi Andrew,
You might like to try this http://www.gwicks.net/downloads.htm as you can download Geoff Wicks program QL2PC which converts Quill and Perfection documents to rtf format, text and html.
Cheers
Cheers
Thank you ! This might be exactly what I needed !Artificer wrote:Hi Andrew,
Cheers
If anyone wants to download it - the link on the page is broken. The correct link is http://www.gwicks.net/files/ql2pc.zip
Later Edit:
It doesn't work as it should
;EditorPrfx:46711; ;PHM 3 ;PFM 3 ;PPL 66 ;PFT2 QL ADVENTURE CREATION TOOL - SPECIAL EDITION August 1988 ;PHD1 CONTENTS BACKING UP YOUR MASTER ACT DISK AND OTHER WARNINGS 0.0 THE DEMONSTRATION MINI_ADVENTURE 1.0 OVERVIEW OF ACT 1.0.1 ACT Notational Conventions 1.0.2 The QL CALL Bug 1.1 Fixed Limits of the System 1.1.1 Initial Planning for Your Adventure 1.2 The Organization of Messages 1.3 Object and Location Data 1.4 The Vocabulary 1.5 The System Programs 1.6 The Component Parts 1.7 Adding Colour and Formatting Screen Text 1.7.1 Inserting Colour with the MSGedt Utility 1.7.2 Considerations for Changes of Text Colour 1.7.3 Split-MODE Screens 1.7.4 Formatting Messages 2.0 BEGINNERS GUIDE TO USING ACT 2.0.1
- NormanDunbar
- Forum Moderator
Exported from the Perfection code.
Stripped of all control characters.
Hopefully, this is useful.
I had long forgotten what a right PITA a Perfection export was!
Thank you very much Norm !NormanDunbar wrote:Exported from the Perfection code.
I converted the manual to be rad on the kindle.
I will convert it to pdf and post it here.
One question, is the manual copyright as the software is.
Maybe David Batty, who holds the rights to Digital Precison software, would release the DP Collection.
David Batty does NOT own the rights to Digital Precision software - he just registered a company using the same name.
Freddy Vaccha reverted the rights to the software to the original software authors. Unfortunately, there is no sign of Steve Sutton who wrote the Adventure Creation Tool (and others).
Here are the ACT Manuals that I have converted for my own use on a Kindle.
I have converted the files with Calibre to: PDF, TXT, AZW3
I had to zip up the files, as the forum software did not like the Kindle azw3 format.
- ACT Manuals.zip
- (734.68 KiB) Downloaded 230 times
