Looking for Metacomco Languages
retro_collector
Brittle Membrane
Post by retro_collector »
Hello everyone!
Looking to buy complete versions of Metacomco Assembler, C and Pascal
Let me know what you have!
Thanks
Re: Looking for Metacomco Languages
I used to have all of those. My microdrives were too old, possibly, to use and my ROMs were lost - somewhere in the Garage. I still can't find them. :( I sent my microdrives off to the software museum to be preserved as Giorgio has ways and means to read very old very fragile cartridges.
Oh yes, my backup floppies - every one of about 250 in total including originals too - all refused to work. Jammed solid they were. A disaster. :( :( :(
Good luck with your search.
retro_collector
Brittle Membrane
NormanDunbar wrote:I used to have all of those. My microdrives were too old, possibly, to use and my ROMs were lost - somewhere in the Garage. I still can't find them. :( I sent my microdrives off to the software museum to be preserved as Giorgio has ways and means to read very old very fragile cartridges.
Sorry to hear that Norm!
Well if you happen to find or come across them please let me know!
Thanks!
Bill
If you are struggling to find the Metacomco software, the Prospero Pro Pascal is available for download at:
http://www.dilwyn.me.uk/language/index.html
Also Assemblers are available; Computer One, GST at:
http://www.dilwyn.me.uk/asm/index.html
You will also find much better tools as well.
stephen_usher
Post by stephen_usher »
Here's a floppy image containing Metacomco C Development Kit
http://www.lingula.org.uk/~steve/downlo ... o-c-ql.img
I wrote on the label: "Metacomco C: Compiler, Editor, Linker + Headers"
Of course, to use it you still need the contents of the dongle ROM.
P.S. I also have both the C dongle and a Pascal one, but not the software for that.
The Pascal dongle was fitted on my second QL when I rescued it from the Oxford University Chemistry Department. Strangely the machine had one of the system (JM) ROMs removed but it would work perfectly with the dongle installed.
P.P.S. Using strings(1) on the disk image I discover that Metacomco C is actually the Lattice C compiler!
Lattice 68000 C Compiler (Phase 1) V3.01
Copyright (C) 1984 Lattice, Inc.
And GST Linker
retro_collector
Brittle Membrane
Steve,
Thanks for that. How do I convert the .IMG back to a real floppy on my QL?
Thanks Bill
I attached the img file to a QPC2 FLP drive and read the files.
If there is a physical floppy drive on the PC, you could copy the files to a floppy disk and transfer to the QL.
But to run the compiler the language rom is required, whiich tnis link to another Fotum thread which has the rom image.
viewtopic.php?t=905#p7284
Why not use C68, which a good established C compiler for the QL.
stephen_usher
retro_collector wrote:Steve,
Thanks Bill
Under Linux or macOS you'd use 'dd if=metacomco-c-ql.img of=/dev/whatever-the-floppy-device-is' (when using a root shell).
On a Windows machine you should be able to use rawwrite or similar.
tcat
Post by tcat »
Not sure if of any help, I tried to find out about a possible ROM to RAM toolkit conversion here in the subject.
viewtopic.php?f=3&t=1499&hilit=ROM+to+R ... ion#p12682
You still however need ROM image of respective MetaComco dongles.
Tomas
I loaded the QLC rom image with SMSQ/E EPROM_LOAD command and the compiler seems to work okay.
That said I still prefer C68...
