I have been playing with the idea of trying to convert my IP Router program into a Windows program, written in C#. It's my first attempt at writing a C# program. Come to that, It's my first attempt at any kind of C program.
For those not familiar with the IP Router, It's a program for connecting the two different types of my IP Network driver together. It usually requires a separate copy of a QL emulator to run in, as it will not run correctly alongside the IP Network driver on the same emulator.
The program is a bit rough around the edges, and I am not entirely happy with the error handling. But I have managed to get something together that seems to work on my system, and I would appreciate any feedback on problems seen, or suggestions for improvements, before I go much further.
Run the Setup.exe program to install it. It creates a Start menu entry, and an Uninstall entry. It requires the .NET framework V4.5? and will try to download it, if not found on your system.
I had a problem with Avast AntiVirus, in that it thought the program was a IDP.Generic virus, But I think this may just be a false positive.
I have included a copy of the source code in case there are any C# programmers who can spot any major problems with my code.
IP Router for Windows
- Aurora
- IPRouter007Beta.zip
- (209.61 KiB) Downloaded 202 times
- IPNet Router for Windows Manual.pdf
- (108.07 KiB) Downloaded 205 times
- Form1.zip
- (5.4 KiB) Downloaded 209 times
