GWASL MOVE.B
Whopper
GWASL MOVE.B
Post by Whopper »
Hi All,
Hopefully this question isn't quite as stupid as the last one.
I am using the GWASL assembler for a project. I wish to code a line thus- " move.b #$ac,(i2c_clk)"
Where there is also a line -
"i2c_clk equ $1c1c0"
Now this works using EASy68K, and seems legal when I decode the operand in the documentation and 68000 code manuals I have. It just doesn't work in GWASL.
Do I need to change the "move.b", or will I have to use GWASS?
Thanks for reading,
Whopper
You woke me for THAT!!!
Re: GWASL MOVE.B
Whopper wrote:Hi All,
What you want to use is absolute long addressing mode, apparently. Thus, the parentheses around the address (i2c_clk) are wrong. proper 68000 code doesn't have parentheses around addresses, only around register+index (like in "20(a6,index)".
Leave off the parentheses and all should be fine.
While most other programming languages perfectly accept arbitrary parentheses anywhere (Easy68k seems to do as well), GWSASS seems to be a bit pickier here.
