SMSQzine #7 is now available
swensont
Post by swensont »
The next issue of SMSQzine is now available. I have moved my main page to a different site. It is now:
http://swensont.epizy.com/
Just scroll down for Issue #7.
Tim
Re: SMSQzine #7 is now available
Hi Tim,
Thank you for for an excellent magazine.
I use C68 on a Q68 works very nicely....
I tried to look at the ZXzine's. Issue's 1 and 3 will not open for me. I get a 404 page not found, and Avast Anti-virus reports it as a Phishing site.
EDIT - Also noticed that the Included Zip files for 4,5, and 7 are the same. And the Included 1 file will download, but will not open.
And the SMSQzine included Zips's 5, 6, and 7 have problems.
swensont
Post by swensont »
Martin,
All of the files should not be there. I checked them all and made sure to upload any that were missing. I'm keeping track to see if the web service deletes any. I've tested all the zips and they are different and they all open for me (using build in unarchiver in Ubuntu).
Tim
swensont wrote:Martin,
Tim
Had a quick check of the one's I listed. The SMSQzine included Zip 5, still has problems.
Hi Tim,
In SMSQzine #7 page 6, you talk about a programme called "qlzip" to add the XTC68 compiled files to a zip archive and add the dataspace into the header.
I do seem be able to find this programme, can you tell me where it available for download.
Derek_Stewart wrote:Hi Tim,
you can compile it from infozip sources.
swensont
Post by swensont »
Martin,
Were you able to download zip #5? Is the zip having issues opening? I did test the original zips to make sure they were all different and able to open.
Tim
swensont
Post by swensont »
Martin,
I checked the website and found #5 zip missing. I just uploaded and tested it. Please confirm that you can now download it.
Tim
Tim
Odd things are still happening.
I Right clicked the ones I am missing (or think I am missing), and selected Save Link As
And got this
I then tried smsqzine06.zip again, and got this
Trying the same with the others, they now download OK
I also noticed that ZXzine01.pdf is screwed up again.
In case it's some kind of browser screw up, I am using Firefox
