I just succeeded compiling and linking some assembler examples found with qmac but when try to run them I get "bad parameter" error, which as I read means my header is corrupt.
I have even created an empty "envelop" for my future exercises but the problem remains. Do you think this code creates a wrong header or maybe I'm completely on wrong path?
BASE BRA.S START The first real thing to assemble!
DS.B 6-(*-BASE) Filler ('*' is where we are)
DC.W $4AFB This is necessary
STRING$ '1' This is the name of the program.
Thank you, Adam
Assembler, header corrupt?
Re: Assembler, header corrupt?
Hi Adam,
Did you put the -nolink directive in the QMAC command line, which puts all the code into a single relocable section and generates a executable header.
Try reading The QL Assembly Language Programming Series by Norman Dunbar, gives good grounding 68000 assembly language on the QL.
- grafvonb
- Bent Pin Expansion Port
Hi Derek, I use Andrew Pennell's book as a start point. I did some demos for Amiga so I think I have quite good understanding what's going on. I have just these "trivial" lamer problems at the beginning
in case of QL.
Do you have a running example of a simple program (MOVE.W #$FF,($20000)
which I can build and link using qmac and finally run it? I own three original QLs but for the start I use QemuLator on Windows and Mac. Is this maybe a problem? And yes I used -nolink option as well as full blown qmac with qlink. Both end with "bad parameter" after ex/ew.
Hi Adam,
Here is a simple Caps Lock Indicator for Minerva, I wrote long time ago, using QMAC.
The Forum Software is messinup the Tab spacing.
The programme is not that good, but it does create an excecutable programme.
Can you upload the programme you having trouble with.
* Minvera compatiable capslock
* using facility to change shape of the cursor
* 14.5.91 v1.0 BASIC program used in multi-tasking basic
* 15.5.91 v1.1 Liberated basic program
* 17.5.91 v1.2 Assembler file
JOB EQU -1 job priority
MT.INF EQU $00 System information
MT.FREE EQU $06 Free Sapce
MT.PRIOR EQU $0B Set prority
SV.CAPS EQU $88 System variable caps offset
SV.CHTOP EQU $7C Minvera enhances System variables
SX.FSTAT EQU $33 Minvera cursor offset
UPPER EQU $53 Upper case
LOWER EQU $4C Lower case
SECTION CODE
BRA.S CAPS Jump to routine
DS.B 4 skip the next four bytes
DC.W $4AFB Job flag
DC.W 9 length of job name
DC.B 'Caps v1.2' Name of job
CAPS MOVEQ #MT.PRIOR,D0 Set priority of routine
MOVEQ #JOB,D1 to run all the time
MOVEQ #8,D2 And use Job priority of 8
TRAP #1
MOVEQ #MT.INF,D0 Find the QDOS System variables
TRAP #1
MOVE.L SV.CHTOP(A0),A1 Start of Minvera S.V.
CLR.L D1 clear register for test
LOOP MOVE.W SV.CAPS(A0),D1 Get condition of Caps Lock
TST.W D1 Find the value is zero
BNE.S CAPSON If nonzero Caps lock ON
MOVE.B #LOWER,SX.FSTAT(A1) must be 0 then caps off
BRA.S LOOP keep on looping
CAPSON MOVE.B #UPPER,SX.FSTAT(A1) Set cursor, caps on
BRA.S LOOP Keep looping infinitely
END
- grafvonb
Hi Derek,
Many thanks for your support. I got the same problem with your code however I did something else. I created an example_link file like this (based on an example from qmac):
With qmac I created a normal example_rel file (setting data DATA default device before) and than with qlink and "-with example -nolist" it created the final example_bin which works!
But I still have no idea why running qmac with -nolink or with just qlink afterwards (where I just use the name of the artifact) the final _bin has a wrong header...
Regards, Adam
filetype 1
data 4k
input example
Regards, Adam
Hi Adam,
I have just realised that QMAC v1.06 Quanta release, the Output File Type can be changed in the CONFIG Block within QMAC 1.06.
You need to use Menuconfig to open QMAC, which will load the default CONFIG blocks, change the Output File Type to 1
This will give an executable file type when the assembly programme has been compiled.
Though, I am sure inserting -NOLINK in the command line did the same thing.
