I recently became the proud owner of a QL but the '1' Key is missing. Can anyone help?
Wanted QL 1 Key
Re: Wanted QL 1 Key
If this is a UK model - I have quite a lot of spare key tops and offer them for £1 plus postage, including a replacement pillar (that they sit on), as that is often the reason why the key top is missing - the pillar is worn or snapped.
Do you know if the membrane is working?
Re: Wanted QL 1 Key
I can give it a quick test. Do you know what voltages the psu should be outputting?
Re: Wanted QL 1 Key
Not perfectly sure - there are various threads on this - viewtopic.php?f=2&t=673 for exampleaxeman wrote:I can give it a quick test. Do you know what voltages the psu should be outputting?
Re: Wanted QL 1 Key
So you will need a membrane too - £12.50 plus postage - I will pm you
