EDSPR under QPC2 doesn't work
Does anyone tried to run QPTR's EDSPR successfully under QPC2? I have tried it (as SBASIC), but beside the pointer loop nothing happens. Selecting anything (the grid, functions, files) makes no action.
Beside the COMPILED in line 100 I have changed nothing.
Any ideas?
Any ideas?
Re: EDSPR under QPC2 doesn't work
Did you leave the lines mnch=0:pdch=1 :CLOSE#1,2
OPEN#mnch;con_2x1a0x26: INK#mnch;0
They are essential for the init procedure to outline the primary window mnch(#0) as it is the channel the pointer is read in.
Cheers
Cheers
As I said, I have just changed "COMPILED" in line 100, (as it is now a SMSQ/E function) into "compile", nothing else.
Beside this, a REMark in the first line says, it is v0.02.
mnch needs to be opened as #0 otherwise the outline won't be set correctly. The code seems to set mnch to be 5 or 6 if run as is. The whole if compiled clause needs to be changed to give the code above.
Cheers
Cheers
Hmm, makes me wonder, as I have tried the test program of the QPTR manual for RPTR just to get the pointer coordinates back, and that worked with #3. But it did not work with QPTR's OUTLN instead with OUTL from Marcel's Demo WIN. Whatever the differences may be.Artificer wrote:mnch needs to be opened as #0 otherwise the outline won't be set correctly. The code seems to set mnch to be 5 or 6 if run as is. The whole if compiled clause needs to be changed to give the code above.
QPTR overwrites QPC2'S OUTLN, from weherever OUTL comes from. But that worked.
I tried compiling EDSPR_bas with Qliberator, on SMSQmulator, with QPTR toolkit v0.14.
I had to change Lines 100 and 105 which had a keyword clash with the Turbo Toolkit COMPILED function, to COMPILE in each line.
Qliberator compiled the programmed OK and the object code was executed as expected.
Ah, that's where COMPILED comes from (I should have known this...). Unfortunately, a lot of programs used this as a variable (incl. TT), maybe, because once it was written in the QLib manuals demo programs.
No luck at all. it still doesn't run in Basic (same as before) and compiled it give Qlib error "Unknown Channel ID". Perhaps someone can put his working SBASIC version here.
Edit1: For test purposes, I have tried a clean QPC2 with just QPTR loaded. Same result in SBASIC. Pointer runs, but nothing else.
Edit2: Ok, next test, recent version of SMSQmulator (also clean started with just QPTR). Here it works, very mysterious.... So there must be something with QPC2, which I do not know.
Any ideas?
Any ideas?
Hi Ralf,
I had a look at 'edspr_bas', I could compile and run the Qliberator object file, but executing a SBASIC job failed or running from SBASCI job 0 failed.
So I looked at the source code, looks a little bit of a mess, the programme has been written to use I/O channels explicitly defined, that is channels 5,6.
So I replaced the open channel statements with FOPEN channel statement, to use the next available channel number. Just is case channel number used in the original 'edspr_bas' were taken. This affect channels: mnch, gpch and pdch. Note pdch is defined with an open statement in PROCedure pulld.
I removed the COMPILED select statement, as I think programmes should open their own channels.
Attached is the amended source code to 'edspr_bas', I usually put the version number after the programme name and before the _bas suffix. Not, the file is zipped, because the QL FOrum Attachment software gives an error to the _bas and .bas extensions.
I have test this in SMSQmulator, QPC2, Q68, UQLX with Qlib compiled and Multibasic.
It seems running from QD using the QS/BAS Thing, needs an extra OUTLN statement for channel #0, but I think O do not understand the OUTLN command, so back to the reading the manuals.
- edspr01.zip
- Update to QPTR EDSPR_BAS
- (6.56 KiB) Downloaded 222 times
