QPC2 freeze on Win 10 laptop going to sleep
After one of the recent Windows 10 upgrades, QPC no longer wants to survive the laptop going to sleep (on two computers), but rather results in freezing - Is this something that is known or even has a known fix?
(I also sometimes have my problems when coming out of sleep mode myself, so can very well understand QPC - but that specific matter has not resulted in a complete freeze as of yet, luckily ;) )
Re: QPC2 freeze on Win 10 laptop going to sleep
Did you try CF12?
pjw wrote:Did you try CF12?
Doesn't do anything.
I just realized it's not necessarily sleep mode, QPC already freezes when I press <CTRL><ALT><Delete> to get to the "Lock"/"Logout"/"Task Manager"... selection screen and back with Escape.
I regularly get this issue with my HP laptop and have asked about it here in the past.
It's not consistent - sometimes I leave the laptop to go to sleep and it happens, sometimes it happens after closing the lid to put the laptop to sleep. Sometimes QPC2 survives come what may.
I'm used to it, and make sure I save consistently until the source of the issue is found.
dilwyn wrote:I regularly get this issue with my HP laptop and have asked about it here in the past.
It's not consistent - sometimes ...
I had that never before, but now it is very consistent here since one of the last Windows 10 updates. I press <CTRL><ALT><Delete>, then <ESC> and QPC freezes. 10 times out of 10. Happens on two different laptops.
All seems to be well on a Windows 7 machine.
On my Windows 10 desktop computer it doesn't freze. Tried several times <CTRL><ALT><Delete>, then <ESC> and QPC still works.
bixio60
Brittle Membrane
Post by bixio60 »
Do you have "Always on top" (QPC2 startup screen) checked ? if yes, try to uncheck.
On my Win10 system QPC freeze if checked.
Fabrizio
Also - do you have QPC2 running with a screensaver in it or similar? I wonder if it is that QPC2 cannot read the mouse / keyboard, or does the image actually freeze if it was doing somethingg graphically at the time?
Marcel has actually contacted me and provided a binary that seems to fix the issue.
Problem's gone.
tofro wrote:Marcel has actually contacted me and provided a binary that seems to fix the issue.
Problem's gone.
Same here.
Still get the fast cursor for a while after QPC2 wakes from sleep, but at least the freeze problem has gone now.
