Zip to MDV
Zip to MDV
Hello, all!
I would like to use QLAY (inside DOSBox) as an emulator for Sinclair QL. QLAY uses MDV images
and this is not the favorite format for distributing QL software. Yet, there is a tool, mdvtool
( https://github.com/mist-devel/mist-bina ... ls/mdvtool ) which
seems to do a very good job, since it can create MDV images from zip files, preserving of course
the structure. But, I was not able to compile it, neither on Linux, nor on Windows.
Does anyone have a compiled version of that program?
Thanks!
Thanks!
Re: Zip to MDV
mdvtool is compiled with mingw32, but completely untested.
I found compiled version, which may not work. Probably best to compile the source again.
Re: Zip to MDV
Thanks for your reply!
I tested the executable giving various parameters,
but unfortunately, as you have guessed, it doesn't work.
It gives the error message: Assertion failed: sizeof(file_t) == 64, file mdvtool.c, line 789
I will try again to compile from the source.
- NormanDunbar
- Forum Moderator
Re: Zip to MDV
Sounds like the usual problem I'm in the middle of fixing for qxltools. Structure field alignments.
- XorA
- Site Admin
Re: Zip to MDV
Yeah it was never in the C spec that you could guarantee the placement or alignment of structure members, people just learned to rely on behaviour from certain compilers.NormanDunbar wrote:Sounds like the usual problem I'm in the middle of fixing for qxltools. Structure field alignments.![]()
Modern compilers move the values to generate less instructions on modern wide bussed CPU's
G
Re: Zip to MDV
I tried to compile the mdvtool.c file, which gave an error:
There maybe be other parameters passed in the new function. So replacing the function name may not work.
Looks like mdvtools uses zip_get_file_extra, but ZIPDEV library, it has been removed and now the function is: zip_file_extra_field_getmdvtool.c: In function ‘zip_import’:
mdvtool.c:585:27: warning: implicit declaration of function ‘zip_get_file_extra’; did you mean ‘zip_get_file_comment’? [-Wimplicit-function-declaration]
const char *extra = zip_get_file_extra(zip, i, &len, 0);
mdvtool.c:585:27: warning: initialization makes pointer from integer without a cast [-Wint-conversion]
/tmp/cc254guW.o: In function `zip_import':
mdvtool.c:(.text+0x192c): undefined reference to `zip_get_file_extra'
collect2: error: ld returned 1 exit status
Makefile:7: recipe for target 'mdvtool' failed
make: *** [mdvtool] Error 1
- mk79
Re: Zip to MDV
True, but I've never come across any that didn't have a #pragma pack support and with that the layout is again well defined.XorA wrote:Yeah it was never in the C spec that you could guarantee the placement or alignment of structure members, people just learned to rely on behaviour from certain compilers.
- XorA
- Site Admin
Re: Zip to MDV
Yes but that gets quickly into #if/#define messes as they are compile (and in some cases compiler version specific *glares at gcc*), would have been nice if the spec gods had acknowledged the heavy use of C in embedded and just gave us a new packed datatypemk79 wrote:True, but I've never come across any that didn't have a #pragma pack support and with that the layout is again well defined.XorA wrote:Yeah it was never in the C spec that you could guarantee the placement or alignment of structure members, people just learned to rely on behaviour from certain compilers.
Re: Zip to MDV
The compilation problems were why I started QLFiler in Java - it can read .zip .mdv and .win files and 'just works' on any system with a Java runtime.
However, there didn't seem to be any interest in the project so I didn't go any further with the needed write functions to save out .mdv files.
Code is here if you're interested: https://github.com/atoone/ql-filer
Re: Zip to MDV
Hi Tuna,
I am interested in QLFiler, but have no experience of Java.
Wolfgang Lenerz wrote a programme called QXLWINREADER in Java to read and write to QWA container files, which is a useful application.
