How to work from CF card from QL in Q-emuLator?
Jack_Free
Post by Jack_Free »
How to work from CF from QL in Q-emuLator?
How do I open a compact flash card in Q-emuLator?
I would like to join and edit my CF card I use on my QL in QUBIDE.
I would like to join it as a WIN drive.
Is this somehow done?
Sinclair QL + SGC, Sinclair QL+QL-SD.
Excuse my English, I use google translator :-)
Re: How to work from CF card from QL in Q-emuLator?
Jack_Free wrote: Is this somehow done?
No. I don't see any obvious way to do this (other than copying the complete CF contents to a win drive/native file system).
Jack_Free
Post by Jack_Free »
my mistake, I asked if there was any help? :-)
So you can help me somehow?
How do i have to proceed ?
I can use a CF cart or I can copy my data to an SD card.
I have both QUBIDE and QL-SD, each device in another QL.
What is it - win drive / native file system?
My English is very weak, I'm sorry.
Jack_Free wrote:How to work from CF from QL in Q-emuLator?
QEmulator (registered version only) can open QXL hard drive image files, as used by the QL-SD drive (the new version)
You have the older QL-SD drive, so if you have not updated the driver to the Marcel's latest version, you are still using the QL_BDI.win file which cannot be opened by QEmulator (but can be opened by QXL reader)
So probably you have to:
1. copy all data from CF to SD card
2. open the SD card QL_BDI_win in QXL reader - ad also open a blank QXL.win image
3. Copy everything from the SD card to the QXL.WIN image using QXL reader
4. Open the QXL.win image file in QEmulator registered version !
I think that you'd better update your QL-SD driver to Marcel's latest version, so that it will use the QXL.win ...
Jack_Free
Post by Jack_Free »
What is QXL reader right now?
Edit: I know clearly, I got it from you on the disk
QEMulator can have the QL-SD extensions installed so the the emulator can read QL_BDI files.
The extension files are in the QL-SD Starter Pavk, abailable on QL Homepage.
I thought the new QL- SD driver worked on the older version of QL-SD.
I will get my real QLs out and try this out.
Jack_Free
Post by Jack_Free »
Great thanks, thank you very much for the advice, I'll look at it.
Jack
Jack_Free
Post by Jack_Free »
Derek_Stewart wrote:Hi,
Could you please specify the address from which it is possible to download?
Thank you.
Jack_Free wrote:Could you please specify the address from which it is possible to download?
Thank you.
https://www.kilgus.net/ql/ql-sd/
Thank you.
The QL Hompage in the QL-SD section.
http://www.dilwyn.me.uk/qlsd/index.html
Lookst the QL-SD Starter Pack zip file, there is a file included on the zip file called: extensions.zip
Which has the required files to extend QEMulator to use QL_BDI files.
The instfuction file is in German, I have translated it to English if required.
