One of my DOMs for Qubide causes this message when booting my QL: fat is wrong, try rebooting...
If try to format it again (with "format win1_") I get "in use".
Any ideas what is the reason for this?
Any ideas how can I fix it?
The data does not matter, I just want to use my DOM normally again.
I use Minerva 1.98, TK2.28, Qubide 1.56
Qubide Fat is wrong, try rebooting
- NormanDunbar
- Forum Moderator
Re: Qubide Fat is wrong, try rebooting
I don't have a Qubide, but I suspect you probably need the win_format command before the format?
See https://superbasic-manual.readthedocs.i ... ormat.html for details.
- Over Heated PSU
DOMS..... XM A LOT O PAIN IN QUBIDE I LOST 3 OF THEM 128MB EACH
SO IF YOU PUT IT IN A NORMAL PC THE WINDOWS SAY FORMAT......
SO YOU FORMAT IN WINDOWS AND IF YOY ARE LUCKY ..... IT WIL BE 128MB(I THINK WILL BE LESS 122 IF I REMEMBER)
SO PUT AGAIN THE DOM IN QUBIDE AND RE FORMAT IT ALL=0 AN BLOCK SIZE 8
IF THE DOM IS CHIP OK..... WIL BE FORMAT FRO QUBIDE IF ITS NOT IN THE NEXT REBOOT OF THE QL YOU SEE AGAIN FAT IS .......
THE DOM IS LOST...... DAMAGED AD YOU CAN DO NOTHING .....
A TIP WHEN YOU TRANSFER A FILE FROM WINDOW TO DOM (WITH HABI 1,1 )ALWAYS PUT THE HEADERS ON QL AND UNCLICK THE EXTRACT
IF YOU DOT DO THIS THE NEXT TIME THE HABI'S SOTWARE WILL CAN OPEN THE DOM.....ACCESS VIOLATION .... AND MAYBE THE FAT IS WRONG ON THE QL
(TRUST ME I LOST TO MANY HOURS ON DOMS AND
I FOUNT THE CF CF-IDE MOST RELIABLE SOLUTION O THE QL I HAVE 3 CF (TRACENT 128MB X80) AND WORKS FINE
SO NOT ALL THE CFS AR COMPATIBLE WITH QUBIDE
SORRY FOR MY CAPITALS.....(PROBLEM WITH THE LAPTOP)
- grafvonb
- Bent Pin Expansion Port
Many thanks for your comments. I have managed to format my DOM (the 3rd try was successful) however I'm surprised that DOMs are so sensible.
