Hi all
Just got hold of a pcml q+ Disk interface I know they either came with 0k,64k,128k or256k of ram does anyone know how I find out what I have got on mine.
Many thanks in advance
PCML Q+ Disk interface ram fitted or not?
- Chuggy Microdrive
Re: PCML Q+ Disk interface ram fitted or not?
Normally, the function RESPR(0) will return the address of ramtop, this can actually be used to find out the size of memory attached to the QL
PRINT RESPR(0)/1024-128
You could load Toolkit 2 and use the FREE_MEM function. Or upload a photograph with the cover off.
- Chuggy Microdrive
Most PCML interfaces had 256Kb of ram, from the blurrly photograph, the memory chips look to be 256 chips.
You always put the interface into a QL with Minerva installed, which tell you how ram the system holds.
