IP Network driver and IP Router update
Martin Head has issued an update to his IP Network driver and IP Router software.
Available to download from http://www.dilwyn.me.uk/internet/index.html on my website, or from http://www.greybeardz.com/internet/index.html
IP Network driver version 1.14
Adds support for sub-directories added to the end of NFS_USE devices e.g.
NFS_USE shd,n3_win1_prg_
DIR shd1_games_ returns a directory of win1_prg_games_ on network station 3.
Also supports QPAC2 when using network servers.
Adds a NET_VER$ function to return the program version number, or the currently set network type (internal or external).
Fixes problems inherited from the original QL network driver with RENAME on file servers and NFS_USE devices.
Fixes problems with RENAME via the IP Router program.
Child FSERVE jobs now have a higher job priority in an effort to improve network speed.
IP Router version 1.03
Adds FROUTER, a function version of the ROUTER command.
Child router jobs now have a higher job priority in an effort to improve network speed.
bixio60
Brittle Membrane
Re: IP Network driver and IP Router update
Post by bixio60 »
it seems that there some issue between new SMSQmulator 2.27 and IPnet 1.14, I always get "Network aborted" error.
Same boot and configuration with SMSQmulator 2.26 works fine with IPnet.
Wolfgang is already informed.
No one else reported this issue and I hope doesn't depend on some specific configuration of mine :)
Regards
Fabrizio
dilwyn wrote:Martin Head has issued an update to his IP Network driver and IP Router software.
