QPC2-CONFIG
mhanias
Brittle Membrane
QPC2-CONFIG
Post by mhanias »
Suddenly the QPC2 on Windows XP (VIRTUAL MACHINE ON MAC) starts automatically , passes the configuration screen.
I reinstall but nothing changed Any help?
Re: QPC2-CONFIG
You most probably checked the "Don't show this dialog on startup" item in the configuration dialog.
Pressing the shift key when starting the program will bring it back temporarily, then uncheck that item.
mhanias
Brittle Membrane
Re: QPC2-CONFIG
Post by mhanias »
Solved deleting the .ini file at roaming data
