(I'm posting separate threads for my Q68 questions to hopefully keep the discussions narrowly focussed and maybe help other Q68 novices when they search for answers)
Can I safely attach the QLWA files on the SDHC card to Q-emuLator? Given that the QLWA files are fixed length, I assume inserting the card into my Mac or PC and attaching the QLWA file to Q-eMulator is OK? (ie won't affect the contiguous sectors requirement that Q68 has for its container files)
I want to do this to start transferring my programs over. If this is not recommended, what is the correct procedure?
Q68 - can I use QLWA on SDHC card with Q-emuLator?
- Sparrowhawk
Re: Q68 - can I use QLWA on SDHC card with Q-emuLator?
The answer is yes.
The QLWA.WIN file on the Q68 SD Card is a standard QWA.WIN or QXL.WIN file, I used SMSQmulator to update the files.
If you put the the SD Card in a PC or MAC and point QPC2/Q-EMulator/SMSQmulator to the file as a WIN file in the emulator, then you can update the contents.
There are othrr ways, but this simple one.
The answer is yes.
- Sparrowhawk
