Cant get passed monitor. Tv select screen
broj446
Post by broj446 »
Im new to sinclair ql and im pressing f2 but nothing happens?
Sent from my SM-G950F using Tapatalk
Re: Cant get passed monitor. Tv select screen
Hello broj446
Welcome to the QL!
If you are seeing the display of the F1/F2 options, but nothing happens after hitting either key, chances are that you have a defective keyboard membrane and your keystrokes are not being detected by the, otherwise working, QL.
That's easy (and pretty cheap!) to address as replacement membranes are available for purchase from RWAP Services on Rich's 'Sell My Retro' site: www.sellmyretro.com
You'll find fitting instructions are provided as part of the kit you receive. There is also a great deal of excellent QL troubleshooting info around this forum.
Good luck :-)
broj446
Post by broj446 »
Thanks for the reply i had a feeling might be the case but was just checking incase i was missing something and it just took time to warm up or something. Ill keep updated and if have any more questions
broj446 wrote:....and it just took time to warm up or something....
Did you try taking out the tubes and polishing them? What shade of orange are they glowing? :P
broj446
Post by broj446 »
Funny guy just meant load time
1024MAK
Post by 1024MAK »
Aww, Dave, you know that you're not suppose to talk about caressing your flux capacitor in public :shock:
:!: Standby alert :!:
“There are four lights!”
