Sandy CP/Mulator
Sandy CP/Mulator
Was there ever a manual for the Sandy CP/Mulator?
I have a ROM cartridge, a microdrive cartridge and disk, but no manual...
Re: Sandy CP/Mulator
Yes, there was a manual. I don't have a copy, or I would post it for you.
I was wondering if a manual for CP/Mulator ever surfaced anywhere please?
t0nyt wrote: Tue Apr 30, 2024 4:06 pm I was wondering if a manual for CP/Mulator ever surfaced anywhere please?
Also, does anyone know if the MD that comes with CP-Mulator contains the same files as the floppy disk please?
I have a good floppy disk (and image) of the CP-Mulator software, but the MD I have actually seems to be just part of a different CP/M
RWAP wrote: Fri May 18, 2018 10:17 pm Was there ever a manual for the Sandy CP/Mulator?
I have the manual. I attached a scan.
I also have a Basic-80 MBASIC Reference manual - I do not know if it was part of the CP/Mulator kit or an add-on from the previous owner
t0nyt wrote: Tue Apr 30, 2024 6:12 pm Also, does anyone know if the MD that comes with CP-Mulator contains the same files as the floppy disk please?
My CP/Multaor disk has the following files:
boot1
boot_cpm
CCP_SYS
CPMU_EXE
G.B_
M __
QLBDOS
Z80_EMU
asm_com
CBAS2_COM
COPY_COM
CRUN2_COM
DEBUG_COM
DUMP_COM
ED_COM
ERQ_COM
L80_COM
M80_COM
MBASIC_COM
PIP_COM
STAT_COM
SUBMIT_COM
XREF_COM
_HEX
_PRN
The mdv has only the following:
boot_bas
clone_bas
cpmu_exe
install_bas
rdcpm_exe
@menu_com
CPMulator.pdf
(2.18 MiB) Downloaded 120 times
Hi Andrew
Many thanks for the Manual!!!
My Floppy (which has the original label/serial no to match the plug-in ROM) only has the files that you have on your MDV
The files on your floppy had me a bit confused. Then I realised I had previously downloaded a zip from somewhere (maybe from another thread on here?) which had those same files as on your floppy. That seems to be a version of CP/Mulator that runs WITHOUT the ROM being inserted (at least it run's in Q-emuLator, not tried on my QL yet)
EDIT: one big difference is that the disk that came with the ROM is v2 while the version that doesn't need the ROM is v1.3
Andrew wrote: Tue Apr 30, 2024 11:38 pm
boot1
boot_cpm
CCP_SYS
CPMU_EXE
G.B_
M __
QLBDOS
Z80_EMU
asm_com
CBAS2_COM
COPY_COM
CRUN2_COM
DEBUG_COM
DUMP_COM
ED_COM
ERQ_COM
L80_COM
M80_COM
MBASIC_COM
PIP_COM
STAT_COM
SUBMIT_COM
XREF_COM
_HEX
_PRN
boot_bas
clone_bas
cpmu_exe
install_bas
rdcpm_exe
@menu_com
I have cleaned up the CPMulator manual.
But there is Page 1 of the CPMulator manual missing.
